rear coil springs
wilcfr
Is it possible to switch the rear leaf springs for coils on a 98 Tahoe?
Sure. You'd need to convert to a link-style suspension very much like what is done when a truck is 'bagged.
W
wilcfr
Okay so that brunvs up another question I've had. When you do the air suspension do you remove the leafs and replace them with the bags? My reason for asking is my interest in improving ride quality on my 98 2dr.
Leaves do two things: support the truck AND locate the rear end, so they're kinda like the links. Bags can't hold a rear end from moving all around (look under your truck and imagine what's left if the leaves were gone), so the rear needs to be connected to the frame via link bars. There are bolt-on kits to convert to bags and maybe even coilover setups for trucks, so I'd imagine one for an SUV is available or easily fabbed from the truck setup.
Sargreky
