Crcz71
ok I have a 2002 tahoe z71 I've owned it for theee years now. When I purchased it I replaced all the brakes and the rear calipers rear hoses and rotors. I did all that to the rear cause they seemed to be sticking. Everything seems ok for awhile but about 8 or 9 months later I had to replace pads again. Now exactly a year after the second pad replacement I'm changing pads again. The abs light is on and the culprit seems to be the abs board. I tried to remove it the other day and the last torx head stripped. I'm going to attempt to cut a slot in it with a Dremel to get it out. That way I can resolder the points on the board. Could the abs malfunction be causing the rear pads to wear out so frequently? I'm still on the front pads I installed on the first brake job I did. They look great with not much wear. Any help would be appreciated hopefully I've explained it clear enough. Thanks.
