Reaiming headlights?
Tim Quigley
Kingston NY
Okay first off I think these are the best headlights I have ever seen in a vehicle. I'm only having one problem. I'm not sure how to get the proper angle of the headlights. Or even how to adjust them. Can someone please help?
1992rs
OR
Im not sure if you're talking about the actual act of physically adjusting your headlights or how they should be properly aimed, but I'll leave this picture for you and anyone else That I found on HID Planet when I was researching how to aim after my retrofit
- Red line is the height from projector to ground.
- Blue line represents the DOT standard 2.1-2.5 drop. You can go as low as a 3in drop, as thats European Standard, but I personally wouldn't.
*Take all this with a grain of salt if you dont have a tabletop flat cutoff line*
ISU-152
Should be two torx bolts under the hood for each light. One does vertical other horizontal. Not familiar with your year though
nixxxster
Can you post some pic of the beam pattern. Some night shoot too.
Durobans
