Radiator oil cooler fitings on radiator
ROGELIO A GUZMAN
Los Angeles CA
Hey fellas.
Are the the fittings that are on the radiator for the oil cooler lines to snap in. Are they removable. I found a small leak coming from the fitting itself , not the line.
ROGELIO A GUZMAN
ROGELIO A GUZMAN
Los Angeles CA
Update. Well I found out my XL has a aftermarket radiator. I did say in the past that I was getting the mishimoto ,but I changed my mind when the fan clutch fixed my over heating issue. I went to the dealership and the connector that I had is not the same as the oem. So I ended just replacing the inner oring and fixed. Than you guys for all the info. All your tips and advice has sure made owning a yukon very easy.
I feel your pain. The smaller one is the oem fitting, the larger is from the aftermarket radiator.
dzg9
