Rack and pinion part number
Jeff Chisam
I have a 15 ltz that has had a multitude of issues. The latest being a bad pop in the front end. The dealership told me it was a bad gear in steering rack. Does anyone have the correct part number for this? I have found some acdelco online for around $1k I believe will fit but want to make sure. Gm quoted me $2400 for one.
petethepug
Michael
SoCal
It’s deff worth getting a price from an Indy shop. Here in Cali I found the diesel specialist to do the suspension right since they’re not cherry picking ez pz, quick turn around jobs.
The first Indy diesel tech I brought our 08 Denali to swapped out our rack w/ a AC Delco reman unit complete w/ inner tie rods and had the outer tie rods done while it was apart.
Part # for our Denali is 45A1092 for OTR Tie Rods ($50.03 ea) and 19320552 for the Steering Rack Long ($572.76). $270 to install the rack and OTR. I declined the alignment bcs I have a 5 year alignment policy at Big O tire. That saved me $85. The out the door price on the rack, OTR, labor, tax and fluid was just under $1k.
The sweet spot here was having a broken bolt extracted from #8, a new exh gasket installed, a new TPMS sensor installed (from eBay), oil change w/ synth oil. Our service contract paid for $1k of the $1,765.00 bill. We’re ahead almost $2k on the $4k service contract we got in 2014. I’m buying these guys lunch!
BG1988
apparently there is a recall for the power steering on the 2015+ tahoes
Warriorpluto
Do you still have your old electric rack? Id like to experiment with it and try to fit it on my 07.
mikeyss
Longmont, Colorado.
I have wondered if a electric rack swap is possible. I'm assuming since the HyHoe has EPS, then it should be able to at least bolt up. However... I don't know how it would affect the voltage system, I'm sure that electric rack eats up some juice!
Warriorpluto
Maybe so. I ordered an high output alternator from lkq just to have for when i get an electric rack to try
JPeter
