Quick headlight question
Rocinante
Hello all. Recently purchased a 2012 Tahoe PPV. Having some electrical issues(like I should be surprised!!). I have been having a problem with the passenger side low beam going on and off. I doesn't act like its a loose wire, as it goes out intermittently. Bumps do not effect it, just goes on and off when it wants. Kinda vague, I know, but any ideas?? Also tracing problem with reverse lights that don't go out. Love the truck though!! Thanks in advance.
Ron Mills
I too recently purchased a 2012 PPV... no lighting issues so far, just a small water leak from the DS pillar where the spotlight was. I would say start with a new headlight bulb, maybe the filament is broken but makes contact sometimes... backup sounds like a sticky b/u light switch... contact cleaner perhaps if you can access the switch, or replace.
R
Rocinante
Thanks for the reply. Those were my same thoughts on both issues. Will be trying both this weekend. Good luck with your ride.
Ihaveatahoetoo
