Questions on drop and tire size?
jboswell87
Savannah, Ga
Got my 11' Tahoe almost a yr ago comin home from deployment and want to start the drop process. Looking at doing a 2/3 drop and getting either 295/45/22 or 295/35/24 slides. either way I want no rubbing, any pointers would be great.
06xl
MD
You will rub at stock height with either set up only when wheel is fully lock an in reverse other then that you should be fine with that drop alot of members have the 2/3 drop with those tires you mentioned an have no issues .good luck an welcome home solider.
Mlstammerjr
