Push Button Start ?
Cnote1115
Hello I was wondering if anyone knows how hard it would be to retrofit push button start on my 16 SLE? I have a local salvage yard that has a 16 Denali I can use as a donor vehicle.
about20ninj45
If it was stand alone, you would be good to go. Your bcm may be didn't she it would need to be flashed by the dealer
C
Cnote1115
Anyone know what all I need ? Do I replace my Bcm with the Denali BCM?
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
It sounds like a lot of work to be able to forget your keys in your truck
ddubdb3
sounds like quite a bit of work.. if you have the donor vehicle i think i would definitely try it
MVR 155
Illinois
It's going to more complicated than a simple BCM swap, there is obviously an antenna/sensor that picks up the fob, you also have the door handles with the push buttons for lock/unlock. My guess is that the system will need to be complete for proper function
schaffer05
There's also some sort of magnetic switch inside the center console for if your fob battery goes dead and you still need to start your vehicle.
CrackerJack135
