POS power/heated seats
04 TAHOE
Pelzer, SC
Was moving my seat back the other day after wife driving and while it was going back I heard two clicks. Checked under seat and nothing. Put seat in my position because of course the memory crap doesn't work right, anyhow put seat where I like it and went to work. Went on break later tried to recline seat back. Nothing works on either seat as the heat for the seats does not work either. Searched all 13 pages of interior posts but found nothing I could use.
Any ideas would be great. By the way I'm new on here and there are some sweet-ass rides on here. Great job boys and girls and I now how some great ideas for my 04 **'.
Anthony
2004 Tahoe LT (MA)
Westen MA
Not sure, you look under the seats for damaged wires? Also check the fuse box for any blown fuses
04 TAHOE
Pelzer, SC
Yea I checked all that, is there a fuse or relay somewhere else besides the driver side fuse block?
BigBeer
Norway
same problem here...there should be a 50amp fuse in the fusebox that controls this.
After I changed mine, everything worked for a day and then went dead again...
Tried to change it sveral times, but it doesnt help...
Anyone?
04 TAHOE
Pelzer, SC
I figured it out. There is another fuse block under the dash behind the e-brake kinda on the floor. It has a black cover over it with a long black plastic nut. Under this cover is just a couple of fuses/relays. The one for the seats is a aluminum body 30amp fuse/relay. I jumped it and the seats worked for a minute and then blew the 50amp under the hood. So in the morning I will replace both and let you know for sure. But I am perty positive this will take care of it.
Thanks everyone who tried to help.
BigBeer
Norway
I know witch ones you mean. Been under there too. So you think I have to change the 30 amp? Even though it's not burned?
Cant wait, let me know as soon you replaced it!:)
BigBeer
Norway
The one with the green mark right?
When I was down there, I also found this!!
The e-brake had worn off the isolation, cause the wire was not entirely behind the plactic cover. Dont know if this has anything to do with it but...
I'll try it with a new fuse tomorrow and see!
Here in norway, that kind of fuse cost 15$ and I replaced it 7 times till know!
04 TAHOE
Pelzer, SC
Yea thats the one. Had to fight with it today because I think I also have a motor problem that keeps blowing the 30 with the green dot and the 50 under the hood. But it is working for now as long as I dont mess with the seat too much. Nice pics bigbear. Also call around to different dealerships to get prices. You wont find this 30 at advance or napa. Didnt try autozone. But different prices at different dealerships. $9.96 at one in Belton and $26.00 at Anderson.
---------- Post added at 09:26 PM ---------- Previous post was at 09:24 PM ----------
Bigbear check the 50amp under the hood first but I had to replace both the 30amp and the 50amp.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
dang bro, at those prices I'd make me a couple of spade to terminal jumpers so I could run a normal **** fuse until I figured it out. those are supposed to be slow blowing fuses, so if you are blowing them you've got a dead short somewhere.
Eagle
EL PASO, TX
piece of wire with a spade on one side and a spade socket on the other (x2)
olsonk_89
Manhattan, KS
I'm sure he's thinking the same as me. Just crimp a male spade terminal on one end of a short piece of wire and crimp a female spade terminal on the other end. Make two of these, shove one of the males in each of the terminals in the fuse box then put a regular fuse in each of the female spade terminals at the other end of the wires. Make sense?
hassoun
Germantown, MD
i have a similar issue with my 01 Denali driver seat. heated seat ( driver only) doesnt work. when i press the button, the light comes on means the heating element is getting power i assume ? no blown fuses. i didnt check the one under teh dash yet i will tomorrow. does each seat have its own fuse ? or most likely its my driver's heating element ? thanks
BigBeer
Norway
I fixed it so I can use other fuses untill I find the problem. Now I can use cheap 5 amps..
It worked ok for a short time, but now when the fuse blows and I try to put in a new one it blows immediately...the fuse connection has 12,6v all the time...someting must have burnt somewhere.
Before this new problem, the strange thing was that the fuse only blew when I turned the ignition off. Everything worked fine, but as soon I switched of the ignition and took out the key the fuse blew...Getting sick of this....:)
cdhpc2
