I have an 07 yukon 5.3, just did an afm delete and while doing that I replaced all sensors and put new cats on. I put about 1500 miles on it and now I am getting a po430 and po420 code which is low catalyst. Was told to try o2 sensors on the downstream o2s but that didn’t do anything. Anyone have this problem before? Have done some research and haven’t come up with anything other then the spacers for the o2 sensors
make sure the map sensor is reading correctly had a unplugged sensor tripping a P0430
if you lost 2.5MPG you are running rich and burned up the CAT P0420 (typically it's correct if you all ready replaced the sensors)..
i would check live data and see if the CAT is running about 500F to 600F typical idled warmed up...
if it's running any hotter (running rich) or if colder it's not working
they have a cheap reader that works with this at wal-mart it's only 40$ and will read the CAT temp..
If you do I suggest a GENUINE 100% OEM
Equivalent Certified aftermarket and not a random converter you see online that claims to be compatible.
From AP Exhaust is the only 100% OEM
part numbers are
740566 Universal (weld on)
749233 direct fit;...
you could have a small exhaust leak as well you did replace the gaskets? with new ones
