Passenger headlights ..Not working!!>=[
01HDtahoeNJN
Shredding Gnar Daily
North Jerz, NJ
So about four weeks ago my lights started not working... Both high beams... This was after a hid install..xentec hid's... They were giving me problems since I put them in..now my passenger side low beam is out and when the light (driver side) comes on the high beam signal on the dash lights up and stats on even when switching it.... Anyone have any ideas on what's going on?!?
Sent from my iPod touch using Tapatalk
chauncey0337
MLT, WA
Are you pretty sure you installed the hids correctly? Maybe put your previous setup back in and see if you have the same problem. Doing this may confirm if it's the hids or not.
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
Sorry forgot to mention I took hids out previous bulbs back in... Highs and passengers low will not go on
chauncey0337
MLT, WA
Accidentally blown fuses when installing hids??? I'm just shooting in the dark.
01HDtahoeNJN
01HDtahoeNJN
North Jerz, NJ
Well replace lows fuses and there working putting new high bulbs in will update later
ntxstallion
Yeah I was gonna suggest that. I blow one when replacing my hids. Forgot to disconnect the battery. HIDS would not work correctly on my truck until I put in the relay. You may want to look at it.
johnsonwillie199
