OEM fog light kit installation
09Hoe
Chicago
I have a 2009 LS and I'm wondering how hard is it to install? To make it specific I mean by wiring everything thanks!
GreatWhite
San Diego
I installed the OEM kit in my '09 Yukon. The lights themselves were a piece of cake. The switch module was actually easier than the instructions suggested - there are a couple of different trim arrangements - mine just popped out but yours may need some disassembly of the dash. The wiring harness wasn't too bad, but was a bit fiddly to thread through the various openings and the Christmas tree fasteners didn't seem to line up with available holes all that well. You will have to disassemble the underhood fuse box and pull one of the connector blocks off the bottom. The hot wire for the fog lights has to be inserted into the correct hole in the connector block (the illustration provided is technically incorrect - if you are doing this and need help, PM me and I'll go look up the drawing). None of it is too tough, but it does require some basic level of mechanical skill.
Packerfan52
Installing factory fog light kit on my 2007 Yukon
I will be installing my fog lights soon can you send me the drawing for the correct hole in the connector block.....Thanks
bwags
I am installing the OE GM Fog lamp kit and my B5 post already has a purple in it, does anyone know where the purple for the for hot goes?
Thanks,
Brian
Jmar73
I tried my hand with this kit, although the instructions are a bit confusing, I am confident I have the connector in the right spot and a good ground.
Can't get the lights to work, is there any other magic to this? Do I have to pay a gm fee?
You're reviving a 4 year old thread and there's no pictures so how are we supposed to help you? Check your connections, check for power and ground at the light, etc. Hard to be of any more help.
Jmar73
Here's a pic of my connector, looks the same to me as the one that you chase in the link above.
Sorry, when should one start a new thread opposed to adding to one.
I can't see your pic or the ones in the link. The link says "photo not found" and yours has 'IMG" and a box with a square. The old thread is ok but remember Photobucket eliminated most folk's pictures a couple months ago. Probably should have just started a new thread but try re-posting some pictures and more info on the kit.
Not sure that I have image embed skills. Here's a link https://lfjennings.app.box.com/file/239729081461
That just takes me to a place that asks for your login password for your account. Don't "embed" images, upload them. At the bottom of the screen, next to "Post Reply" , there's a box right there that says "upload a file" which allows you to point to the file location on your device. Or you can right-click a pic, copy it, then when you're typing a response you can right-click and paste it.
OK, now hopefully somebody who has installed the kit has a clue what to look for. I sure don't! Good luck.
sick1166
you installed lights good ground. power to fuse box under hood,put in new switch headlight control with fog light control and done
Jmar73
IMG_3319.JPG IMG_3318.JPG Yeah, I think I got all those steps, but doesn't work. It's a ssv if that makes a difference.
The light on the dash isn't coming on either so I assume the computer isn't recognizing it.
Here is a pic of the switch plug, I noticed not all the pins have wires to the harness.IMG_3317.JPG
08SSV
I have the same exact problem (also ssv) no power at the fuse either. Hopefully somebody can shed some light on this.
Tahoe_SSV
Northern New Hampshire
I also would like to do this. My truck is 09 ssv also..I wish somebody would do a write up or video because this seems to be common thing people want to do and there is certainly a way to wire these up to factory switch.
JasonW4141
