No Brake Lights
Duner
This is kind of Embarrassing, but where are the fuses for the brake lights.
Here's the situation. No brake lights, both sides and third one up top. No hazards either. The running lights work fine though and cruise control still works. I went to check the fuse box under the hood, but the brake fuse is missing and it's not wired to even accept a fuse there.
I searched the forums and went ahead and replaced the brake switch under the dash with no help. I imagine it is fuse related, but where are the fuses located? I read on here that there are 2.
Any help is appreciated. Thanks.
1997 Yukon SLT. 5.7 4x4
GMC Yukon
Left side by the door on the dash.... Youll see a pannel.. Pull it off and there they are. should also tell you what is what ! good luck....
D
Duner
Thank you very much. I had a look at the panel, but none of the fuses were blown. However, while in the process of pulling/pushing fuses, I noticed that something behind the fuse panel was loose. Everything now works. Thanks for the help.
bigblackhoe
My 2000 Limited is doing this..
No brake lights right, left or top..No hazards or turn signals..
I do have parking lights..
All the fuses are good..I checked every fuse I found!..Underhood, Dash end..etc.
All bulbs are good...
They worked fine one minute..then didn't...
I wonder what this guy found loose behind the fuse block?
Any help is appreciated..
Jetfan4life
