newbie with a couple suspension questions...
OnE_bAd_HoE
Senior Member
Miami,Fl
whats up guys. my name is carlos i have a 08 tahoe LT2 stock height on 24's with 305/35/24 and im interested in getting a lowring kit for it. I think i want want to go with a 3/5 kit, but i will be towing a boat often so i was thinking about helper bags too. i also want to do the panhard bar and sawy bars
i would like to get some feedback from some people that know. i was thinking on the belltech 1-4/5-6http://www.stylintrucks.com/parts/1-qt-_to_4-qt--fs-_5-qt--_6-qt-_stage_3_lowering_kit/23555/belltechb26647sp-.aspx
is there is a kit that i can put together that will ride better than this?
also will the tires rub when i turn with the car that low?if so how much plastic do i have to remove. any ideas will help.thanks guys
this is what the truck look like now
OnE_bAd_HoE
OnE_bAd_HoE
Senior Member
Miami,Fl
what about shocks? which ones would you recommend?
i am looking for the lowest drop with best ride quality i can get with still being able to haul the boat. by the way thanks for the help
NORCAL SS
SUV SUSPENSION GURU
thanks for your order carlos. texted you the part numbers for the helper bags
Escalade2007
