New to me 17’ LS
GranPrix
So this just happened.. 2017 LS FL Hoe with 69k highway miles. Now I’m trying to get rid of the 11’ PPV
Miami-Dade
Moderator Supporting Member
Looks to be in excellent condition! I will safely assume you have ALL the service records.
BTW please do not ever put Shell fuel in it!
GranPrix
GranPrix
Thanks guys.
Damn what did I miss?? What's the deal with Shell?
GranPrix
GranPrix
Does anyone know if my 2011 PPV TPMS valves will work with the 2017?
wjburken
Eastern Iowa
I don't think so. I thought I read some where that they made a change in 2014, but I could be wrong.
EDIT: I looked and RockAuto shows the same Part number for AC Delco (TPMS171K) for both 2011 and 2017. They might work.
Rdr854
Northern VA
I noticed that I am starting to get a slight rough idle in my 19 Suburban. I generally use Exxon or BP 87 octane, and always top tier gas.
Miami-Dade
I get slight rough idle here there since I bought my Tahoe back in 2016. It is not every day and really does not bother me. If it was major rough idle then I would say something to the dealer. I can not worry about everything.
Every vehicle I have owned [even the Cadillac's] had rough idle every so often. I never mentioned the rough idle to the dealer.
I never had a vehicle [or been in a vehicle] idle as smooth as glass all the time.
wjburken
Eastern Iowa
Same here. Have always had vehicles that would shudder once in a while, at least, when idling. If you think about it, the average car idles between 500-600 rpm. At 600 rpm, that is 5 ignitions per cylinder per second. I’m not sure that what you are feeling is the engine running badly. I think part of it is just that at that engine speed it hits a resonant frequency of the vehicle and that is what you are feeling. Every structure has resonate frequencies and it it varies with how much stuff weighs, how tight bolts are, the variation in material in motor mounts, etc.
rjr
My 2015 didn't idle roug when new, but it does now, especially in summer with a/c on. Dealer says it's normal.
sealandsky
Minneapolis, MN
I know it's not highly relevant as I have a 2019 6.2 (Callaway modified) but my idle is 750 RPM +/- 50 RPM with load variance (fully warmed up). At this RPM the idle is as smooth as silk. So maybe this means that if you can find a way to adjust the idle upwards to the 750 range you may see an improvement.
tom3
On the TPMS deal you can check the RPO codes in the glove box sticker to be sure, different frequencies have different codes - I think. Not sure how long those devices actually last though.
tgui
Stock idle will be lumpy. I tuned both of my Yukons to idle at around 750rpm. High flowing heads supposedly make it hard to perfectly meter small amounts of air for smooth low RPM idle.
I take the high flowing head idle issues in the same vein as my piston slap due to short skirts and looser tolerances. Both add more power. I have a lexus for super smooth driving.
wjburken
Eastern Iowa
Batteries on TPMS sensors have lasted around 7-10 years for me.
BadDaddy2003
