New member. Have a quick question.
DaDenaliDude
Hello, I just joined the group. I have a quick question I’m hoping one of you can answer. I have a 2007 Yukon Denali 6.2L. I’m wanting to do some exhaust work. I’m thinking about a Super 44 or Super 10 Flowmaster. My question is what is the pipe size that’s on my truck? I’ve heard people say 3” and others 3.5”.
Welcome to the Forum from NH.
Pics of the truck, please.
My understanding is the the inlet pipe into the muffler is 3.5" and the outlet pipe out of the muffler is 3".
The Walker website shows 3" ID tubing with a 3.5" exhaust tip. I'll put a tape around mine tonight when it gets back to double check.
If you travel alone and like to hear the motor more than the stereo, the Flowmasters are awesome...
alpha_omega
Michigan
x2 on this one. 3” ID w/ 3-1/2” tips.
Welcome to the forum - Michigan here, but I spent many of moons down in NC.
Whatever you decide to go with, just make sure to consider the amount of heat dissipation from your new gear. On some rigs depending on the engine size and style/size of the upgraded header/exhaust there may be a need to either wrap them with a heat tape and/or the need to wrap some of the other “components” (including but not limited to spark plug wires/boots, starter and the electrical wiring running to the starter, tranny coolant lines near the headers…etc).
When I was looking for a new exhaust (2011 Denali 6.2l) I’m pretty sure Doug Thorley shorties were one of the few headers (aside from custom work) that worked with our big @$$ engine, without interfering or needing to wrap EVERYTHING - headers, plug wires, starter and electrical.
Don’t let this sway you, rather just giving you some food for thought.
Plus I know NC has some emissions laws, so be mindful of any cat or muffler deletes.
alpha_omega
Michigan
You might want to pick something else, the flowmaster's sound alright on the 5.3 but at wide open throttle on a 6.2l sounds like krap
**just my opinion**
Not just your opinion, I agree 100% on that observation. The exhaust on the 6.2l cannot be compared to anything on the 5.3l. Well…I don’t want to say anything, but there are many that sound much different between the two.
Similar concepts apply if you have or plan to do other mods in which systems contribute to the function of others. In terms of the exhaust, they may change the sound a little but you’ll notice it more overall in performance if things are not tuned properly with the addition of other upgrades/modifications.
Beware of the slippery slope…or strap in and barrel head first down the double diamond. Either way there’s plenty of knowledge and experience from the guys/gals on the forum
donjetman
Welcome
I have the same vehicle as you. I went out and measured. It's pretty much 3.5" OD from where the Y meets, all the way back. There a couple of spots where it necks down temporarily to 3.25" OD. Before the Y it's 2.5" OD. Stock exhaust has 165k miles and it sounds SWEET:2cents: . Not too quiet, not too loud.
DaDenaliDude
DaDenaliDude
Thank you. I will post some pictures this week. I’m waiting on some headlights that I ordered that should arrive tomorrow.
DaDenaliDude
DaDenaliDude
I’m with you on that. I’ve had Flowmaster 40 series on all my previous trucks. But they were all 5.3. Might be too loud on this 6.2. (It’s a family truck.) Someone on FB said they did a rear resonator delete and it made it purrr just enough where it’s not obnoxious but it doesn’t sound stock either.
DaDenaliDude
DaDenaliDude
Welcome
Thank you for doing that. I currently have a stock exhaust system as well. It does sound pretty good, I’m not gonna lie. That 6.2 sounds amazing but I was considering replacing the muffler with a Flowmaster to have a little more sound. Someone said that removing the rear resonator and keeping everything else stock gives you a nice little growl on a cole start and when you accelerate. But that again is nothing crazy and too obnoxious.
DaDenaliDude
DaDenaliDude
Thanks for the response. I’m not considering doing anything to crazy seeing as this is my family truck. I just want a little more sound and to be a little shy from stock. You’re right about emissions here in NC. I plan on leaving the exhaust system for the most part stock so I can still pass the emission test each year, with that being said I’ll more than likely just go with a well known Flowmaster muffler and see how it sounds.
TollKeeper
Brighton, CO
The resonator delete works well, unless you have a AFM/DOD truck, and than when cruising, it sounds weird, when it cuts it down to a V4.
There are lots of videos on youtube where pickup owners deleted the muffler and kept the resonator to eliminate drone and sounds great (subjective). Glad Don got to put a tape on his exhaust, every time the Sierra came home it was raining.
Just measured the Sierra's exhaust, 3.5" before and after the muffler.
j_jerry79
