new front bag kit from ekstensive
robb.
dallas
sweet finally a bolt on kit for the 00+tahoes......
i had the air ride tech shockwaves....they were hell ...and i could never get the correct rideheight with out sacrificin my tires..negative camber ate them up .....plus those things would damage easily..
G
groundscr8pr
flaccid member
scarborough maine
not really bolt on. but prob the best solution available. you will need to cut off the factory shock mount and upper arm mounts. then locate and weld the plate on.
SS HOE
Wilson, NC
The description on the kit says for 2wd only. Just want to know why I couldn't put this on my 4wd. I lowered my tahoe even though the lowering kit said 2wd only.
CKendrick
