johnnyt5646
- Joined
- Sep 23, 2012
- Posts
- 27
- Reaction score
- 0
I have a problem with my hvac. i hear a squeaking noise coming from under the dash. it sounds like an o-ring is spinning and is squeaking against some plastic. I have the dual temp manual slider controls. i also have rear heat controls that work.
I have noticed that if i have heat blow on the dash and feet, the heat for the feet blows cold but the dash blows at whatever temp i set it to. also when i put it on the winshield defrost, it blows luke warm but not hot. if i have it on defrost and feet, the defrost is luke warm and feet blows cold.
i tried to search for my problem but could not come up with anything. what could be causing my issue.
Thanks for your help.
