Nav Radio Info
TahoeLTZ2007
Looking to upgrade to a Nav system.
I have 07 Tahoe LTZ with bose,6 CD and sat radio,and no DVD.
I am happy with the current sound and features,just want to add Nav.
Need the GM part # of your suggested unit.
I can install
Thanks
Warius3
If you do not want a navigation unit with a DVD, then you need the 15882767. But if you want a DVD as well, the 15882766 is what you need. These units work with Bose only!
The GPS antenna is 15201798 and you will also need a VSS harness.
Sent from my ADR6300 using Tapatalk
strongz
Houston, TX
I have a similar issue. I have a 2010 Tahoe LT with Bose (no nav or dvd). I would like to add Nav and possibly the DVD (but I don't have DVD in the rear). What part #'s do I need to buy (for VSS and GPS antenna too)?
Thanks!
felixgun
Lafayette, LA
FYI, If you have rear seat entertainment/DVD and have an LTZ, most likely you have the VSS wiring pre-wired in your car. I added this to my avalanche and did not need to get the VSS wiring kit...
apex_predetor
I am also thinking about installing a 15882766 in a 2008 Yukon with no navigation.
THis unit is for a truck with BOSE right, but this is where I am confused.
I will need to ahve an amp installed right, and then get it reprogrammed to my vehicle?
Since my VIN will not show up with the BOSE system, will I need another VIN with that BOSE radiop for the tech?
Thanks all
veteran111
