Max towing
GMTech49
just curious what the max anyone has towed with 2007 or 08 Tahoe without problems???
zach2011
Platinum Member
So does this mean a 2010 Esky can tow a 24' boat? We're planning on buying a new one soon so I figured I'd ask in this thread rather than create a new one.
ICON
Bellingham, WA
zach2011: Depends on the boat. On Average 24' Boats with twin outboard motors and full trailer weigh 6000lbs+
150lbs Per foot on a 25' boat and smaller, not including accessories.
CIATAHOE
Orange County, CA
I had a 2008 tahoe 5.3L, 26" wheels, 2/3 drop, 4 people, full loaded truck (coolers/ luggage etc) to havasu towing my boat that weighs approx 4500-5000 pounds. It pulled it great, little harder up the big hills (outside temp about 95-105), trans temp got up a little, but really had no issues. I dont speed when towing so 55 mph no problem even up the big hills.
stevek
Dallas, TX
At 6300ft I tow 3500ish lbs and it is a little sluggish because the air is so thin. I know it will keep going but it's slower than it is relative to towing a similar weight at lower altitudes
Conor
"Bob's your Uncle"
Seattle, WA
I have pulled a 6500 lbs Donzi with no issues. What you have to be carefull of when towing is making sure you have good brakes on the trailer as well as knowing what your toungue weight is on the trailer. You also need to keep an eye on your trans temp, and installing a tranny cooler is not a bad idea either. I would also do a tranny service before summer as well.
Your Tahoe should have no issues what so ever pulling a 4000 lbs boat. That is the only reason I am driving a Tahoe and not a Cayenne right now is to be able to tow.
---------- Post added at 08:56 AM ---------- Previous post was at 08:54 AM ----------
Absolutly Zach. An Esky is a pretty serious tower with that engine
LTZboy
What is the normal range for the trans temp. I have heard one member state that it should never get above 180 without causing damage.
Conor
"Bob's your Uncle"
Seattle, WA
Im pretty sure mine runs in the high 170's under normal highway driving with a fresh tranny service, so I dont think there is much truth to that. But it would not be the first time I have been wrong on a post.lol
stevek
Dallas, TX
Mine has been in the high 190's when towing up and over a mountain pass. Obviously when you're driving up and down mountains you don't go past 3rd to try and save your brakes for when you may ACTUALLY need them.
D Rollins
