lq9 help
trublew
Sorry if this is a repeat thread, but I tried searching and couldn't find exactly what I wanted... I found a 6.0 from a 03 escalade esv, low miles, good price... Now other than a tune, what exactly do I need to put it in a 02 hoe 4.8L? And even though it came from a truck with awd, will it bolt to my 4wd Trans? Again sorry if it's been covered and I missed it, I just.don't want to waste my money...and I need to start buying anything I'll need for the swap.
Physh1
It'll drop in BUT you should use your 4.8 intake so it's completely plug & play. Trans is fine...get a tune, might want to get a performance torque converter since you'll have the engine out, check motor for leaks (intake, oil sender, oil pan gasket, check for corrosion on the knock sensors, etc), & for peace of mind maybe replace the water pump.
Cameron
T
trublew
When you say use the 4.8 intake are you talking about the black plastic plenum or the actual manifold? Is it different then the 6.0?
Blacked-out-Tahoe
Washington
The black plastic intake is the plentum. Hes saying that to make it easier for the wiring harness and injectors to not have to mess with new connectors
T
trublew
So reuse my intake and injectors from the 4.8... The 6.0 doesn't use bigger injectors?
Blacked-out-Tahoe
Washington
Yes the 6.0 should use bigger injectors but I'm not certain how much bigger they are. If I was to do it I would use the intake and injectors that come on the 6.0 and if your wiring harness doesn't work with those injectors they make a pigtail adaptor for swaps like that so your harness will plug into the injectors
T
trublew
ok, any idea who sells the adapters by chance?
T
trublew
Ok, so worst case scenario I'll need these adapters, and other than that everything should be the same right? Ty for the link btw
JennaBear
Resident Ninja
San Diego, CA
They are the same injectors. Only 8.1 and flex fuel are different. Same intake manifold as well.
Sent from an ice cream sammich.
02chevyhoe
I have a 02 5.3 flex fuel. What would I need to go to I install a 6.0? Just install my flex intake and injectors on the 6.0?
Stein2088
Butler, PA
I'm working on doing the exact same thing.... Just curious since the intake has is the discussion here... No one makes an aftermarket one that flows better for our Hoes??? Ive looked around but I havent found anything out there... Also if I under stand this correctly my intake is what makes my vehicle FLEX capable.... interesting!!! yet good to know!!!
Thanks!!!
JennaBear
Resident Ninja
San Diego, CA
Not just intake, the injectors, alcohol sensor, and fuel pump. However injectors from a smaller engine are not large enough for a 6l with e85.
Also depends on what vehicle you have.
Stein2088
Butler, PA
Is it possible to do the swap and keep FLEX??? Also, is it possible to buy a newer 6L w/ active fuel mgt and have it programed for my vehicle???? Currently have an 03 5.3 W/ Flex
JennaBear
Resident Ninja
San Diego, CA
Yes it is possible to keep flex fuel with the swap. Go to bigger injectors. It is not possible to run active fuel management without piggybacked computers. Lots of work.
Stein2088
Butler, PA
So should I keep the stock 5.3 intake and run the 6.0 injectors??? sorry to ask so many questions. And thank you so much for your help!!!
JennaBear
Resident Ninja
San Diego, CA
Nope, flex fuel injectors are larger than 6.0L injectors, but are not big enough to run a 6.0L on E85.
Could get fuel injectors off of a flex fuel 6.2L.
Durobans
