Let's talk foam cannons
Goodinblack
I Like Tacos
Dirty South
THERE ARE 2 Different VERSIONS of the MTM Foam Canons.......
This is the high pressure one. (GAS)
MTM Hydro Professional Foam Lance Adjustable with 32 oz. Bottle
http://www.wayfair.com/MTM-Hydro-Pro...3-MHD1010.html
http://www.amazon.com/Professional-F.../dp/B004GNZYY4
Features:
Also included is an instruction manual on how to get the most out of this great cleaning product
Disperses thick foam to up over 20 feet and at more than a 30 degree cleaning radius
Perfect for driveways, roofs, siding, even your car
Comes with a 1/4'' quick connect and a M22 fitting for easy attachment to just about any pressure washer
Spray pattern easily adjustable
Easily refillable 32 oz. bottle
For home or automotive use
This requires the washer to have at least 2.0 GPM and Over 1000 PSI pressure for use
Constructed from brass and high grade stainless steel for high chemical resiliency
90 Days warranty
This is the LOW pressure one. (ELECTRIC)
MTM Hydro Professional 2600 PSI Adjustable Foamer
http://www.wayfair.com/MTM-Hydro-Pro...9-MHD1109.html
http://www.amazon.com/Professional-2.../dp/B00EDSLVQC
MTM Hydro's High Pressure Adjustable Foam Lance 2600 with attached bayonet fitting is perfect for small electric pressure washers. Specifically designed for pressure washers with a range of 1.1-2.6 GPM and with a maximum pressure of 2600 psi, this foamer is ideal for washing cars, driveways, fences, roofs and walls. Produces thick, shaving cream foam up to 20 ft.
Features:
Attached bayonet fitting fits Karcher electric pressure washers
Also comes with 0.25'' male npt plug and 0.25'' male M22 fitting for most other pressure washers
Shoots thick foam up to 20 ft
Minimum pressure needed 1100 psi
Maximum pressure of 2600 psi
Minimum flow needed 1.4 gpm
Psi @ 2.6 GPM max
Perfect for small electric pressure washers
Brass fitting
I bought the LOW pressure unit and here are some pictures of it.
As an Amazon Associate we earn from qualifying purchases.
yates ™
Resident Apple hater
Iowa
So you do not think they're worth using? I was hoping to get a touchless wash for the dodge that I could to areas underneath also.
ezdaar
Chat Troll
Redneck central, Aka Houston
I thin they are worth it, as the soap dis lodges the dirt and carry's it away encapsulated in the foam. leaving a cleaner surface to begin with the hand wash.
Less chance of dirt contaminating your mits and scratching the paint
Goodinblack
Goodinblack
I Like Tacos
Dirty South
I foam a car then pressure wash it and then foam it again and then wash it.
You cant do this every single time though
Administrator
I think doug just copy and pasted his post from the Adam's website or Surf City Garage LOL
yates ™
Iowa
Ugh. I will just fuggin order one and decide for myself... Is there any difference between the ones posted?
Goodinblack
Goodinblack
I Like Tacos
Dirty South
Make washing your car faster, fun, and more effective with Adam’s Car Wash Foam Gun. This hose-end sprayer attaches to a standard garden hose and allows you to deliver a luxurious foam bath to your vehicles finish using our super concentrated Car Shampoo.
---------- Post added at 03:13 PM ---------- Previous post was at 03:12 PM ----------
[yt]S2MQJbwh7YY[/yt]
yates ™
Iowa
Lee,
Are you now saying the hose attachment is just as good or better than the pressure hose attachment?
CHOO CHOO
BackPagePhil
Manheim, Pa
I like the idea of both. IMO the pressure washer helps take debris off and the soap then helps afterwards. As the garden hose just relays on the soap. Both have their advantages and disadvantages. Garden hose doesn't require gas. Just depends on time allotted to wash as well or how good a job needs done
Goodinblack
Goodinblack
I Like Tacos
Dirty South
LOL
Here is what I personally did.
1. Got a pressure washer from Sams club Black Max
2. Got a gilmore foam gun
3. Got 2 buckets and 2 Grit guards
4. Got a bunch of wash mits that look like this
Use this combination EVERY single week for the past 2 years almost.
I personally DO NOT want to drag the pressure washer out EVERY single time I wash to be able to use the foam canon.
The hose thingy works well enough for me.
It is better to get better soap than better foam gun and bad soap that wont cling and clean.
I have read of some people on AGO that stopped using foam cannons because they feel it is a waste of soap and water.
You may feel the same way eventually..... so I suggest getting a hose foam gun thingy
---------- Post added at 03:31 PM ---------- Previous post was at 03:26 PM ----------
When you are using the foam canon the pressure washer provides ZERO cleaning pressure. Its just gentle foam. The dirt does not get pushed off
pistolpetem9
