Latest OTA update introduced a new GPS 'feature'
N
nomech
The update on 6-18-26 was GM V661.40
Improvements to reliability when extending running boards.
Scarey
Now my hud doesn’t work….again. Not impressed with the software updates, starting to feel like a beta tester.
N
nomech
Not from this last OTA update but from the one just before it, I've notice that when I switch from any view back to the view where it has the radio on the left and the map on the right, the radio tile loads/has a line on the bottom 75% of the window and after a few seconds it fills up and takes the entire left window. A minor annoyance but it never did that prior to the update I mentioned above.
N
nomech
I'm also noticing that I can no longer zoom in on the map anymore (stock GPS, I'm not using car play at this time).
If I try to zoom in/out I can either see the entire world (almost) or my 'normal' zoomed in view. I can't drag/move the map around, either.
2024 White Tahoe
I believe when an OTA update is done, GM should have to email and mail the owner a letter describing exactly what changes were made.
Many of the OTA updates are done while the vehicle is under warranty, and GM is very coy and secretive about the updates and changes made to the vehicle. The work / changes to the vehicle should be documented for the owner (such as a work invoice when the work is done at an authorized dealer).
On one service visit for my 2024 Tahoe Premier, seven updates were done to the vehicle. The service department was unable (or unwilling) to tell me what the changes and updates were meant to do. Although I received a work invoice, it simply stated updates performed.
GM has sold MANY new vehicle knowing they contain known software defects. I believe GM is trying to avoid lawsuits by providing updates but concealing what changes were made to the vehicle.
N
nomech
If techs update the software, does it not list that in the vehicle history on the infotainment screen? I can see the updates I clicked to 'install' but I'm not aware of any that were done by the dealer when I brought it in for maintenance. I didn't ask or look but I do still have all the receipts so I can check, if needed.
LegalBrief
Senior Member
You have to tenable the HUD, via the main settings.. easy peasy
Scarey
No, didn’t work. Played with it for a couple days. All settings. Finally disconnected the negative, reconnect, started working immediately. This is my go to for all electronics issue.
davesproblem
