is my TPMS bad
gtbigup01
Columbus, GA
I recently swithced my stockers to new rime in July and recently or a month or so I always get the low pressure light and it's always the right front indicating no pressure, however when i put my TP guage on it it's fine or at least within 2PSI from the others. Is my sensor going bad?
hoserty
Ft. Rucker, AL
I have an 07 Denali and just recently had the same problem had to replace one of the sensors they get broken during the installation sometimes costed about 65 bucks at the dealer with labor and reprograming.
pittmanb8
If you haven't done it already, try and program the tire pressure sensors to the correct tire. Follow the manual on how to program them and then if one sensor fails to respond, you know its bad. If they all program fine, the people that installed your tires might have accidentally put something on the sensor causing it to misread.
WITCH1975
