Interior lights
4wheelin
Land of Oz
Picked up an 04 Yukon Denali last summer. I'm trying to replace the sunroof switch. Can anyone tell me how in the hell that plastic piece that houses it and the rear climate controls comes off?
Also, is the headlamp switch supposed to be lighted up at night with all the rest of the dash lights?
Just wondering since I need to remove the cluster to replace some burned out bulbs. Figured I'd replace that bulb too if it's supposed to light up.
Any help is great! Thanks.
treehan77
TYF Fiend
Crestview, FL
I was told the headlamps switch doesn't light up but I'm subscribing to see if anyone answers
gtptyler
North Dakota
Around the headlamp dial yes. The dial for the brightness of dashlights would not be lit up. Very early nbs trucks had that lit up but would get too hot
4wheelin
4wheelin
Land of Oz
They do get hot. In my 1999 Yuke, there is bulb that burned out and made some of the area around it melt. I went to Autozone yesterday and looked over a new headlight switch for the 04 and there is no provision for a bulb, which would mean if it does have one then it's internal and replaceable only as a whole unit.
gtptyler
North Dakota
treehan77
TYF Fiend
Crestview, FL
oh ok, i see now. the two spots you might think light up around the dial, don't i guess.
As far as the rear climate controls, I know on my '02 Denali the rear ones just have spring tabs that pop out after it slides into the opening. I slid a couple thin putty knives on the top and bottom to disengage the tabs and it slid right out.
4wheelin
4wheelin
Land of Oz
I got an ac delco switch off of eBay. When it arrives I'll hook it up.
You're correct. I was able to get mine down. Thank you for posting. I really thought I was going to break something trying it, so it was nice to hear from someone else before I took a blind leap of faith at it. I was looking for screws all this time.
Glad I was able to help. It's what these forums are all about.
PexoA78
