Interior lights....
rednose
bootHELL of MO
I have a problem and need a quick fix I have no interior lighting besides dash lights it only keeps blowing fuses #13 cig light I have checked all grounds wires ect. Ect. It did have an aftermarket alarm system but all components what was there got removed
rednose
rednose
bootHELL of MO
I can't keep one in it! My cigarette lighter worked up til last night with the fuse being blown
Donnie Yukonie
Yates Caretaker
like does it blow as soon as you apply power too the truck (i.e key to acsess or to start) or does it blow when you turn your head lights on or play with the dimmer switch?
Gzes
the drifting 2dr
Wichita tx
Wires are probably touching causing the short. Track the wires down and check them
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Any one of the devices on the #13 fuse listed below can be shorting the circuit. disable all of them and reconnect one at a time till a fuse fuse blows.
Fuse 13 - CIG LTR
Instrument Panel (I/P) Fuse Block - Fuses
Notes
62392105
Fuse 13 & 19
rednose
rednose
bootHELL of MO
Problem solved there was 3 bad fuses of course 13 cig lighter..7 auxiliary power...and 9 park lamps which was my lights lol..the main cig lighter still doesn't work but I don't use it anyway thanks
briannorris
