installed lower seat cover today
motsco
I installed the drivers lower seat cover and arm rest cover in my 2d today. real easy to do took about 1 hour in and out.
like to thank the Seat Shop for having such a great product.
pics before and after.
tom
ncdrtyhoe
Looks good! I did mine a while ago bottoms and backs. Talk about a PITA but it is worth it in the end.
M
motsco
thx,
how hard where the uppers to install? the lowers were easy the arm rest was kinda a pia.
Also i see in your sig you changed your carpet. where did you get it and was is cut to fit? i thinking of puting a charcoal colored carpet in.
tom
xanatost
Lafayette, La.
Uppers are a pine as well but if you leave them in the sun or in your truck withy the windows rolled up so that they can heat up its not so bad. Btw looks dam good! I got the same on mine upper and lowers and you won't be dissapointed.
95BlackTahoe
Edinburg, PA
I need to locate a seat bottom cover for my driver side denali seat I am installing in my "Tahoe Unlimited"...Wonder if this seat shop has that.
How did you do the bottom? was it a real pain to do?
Shawn
M
motsco
Shawn
not sure if seat shop has color match for two tone.
I can tell you what i got from them is very nice.
as for installing the lower seat, they have videos on the seat shop web site,
the install is not hard at all, you need a phillips head screwer, 15 mm socket 10mm socket, cutting knife.
the srcewer removes the trim from the seat, the 15mm removes the seat from the truck, the 10mm removes the track from the seat.
Cutt the hog rings, and remove the original cover from the seat then install the new seat cover.
Take your time watch the vid;s is real easy
tom
ncdrtyhoe
The backs aren't that bad. My carpet came from stockinteriors.com. Check out my pics.
qukon 95
where did buy this seat cover? is it leather? how much
did cost. i need the lower really bad.
TallHoe 96 OBS
