Inner door latch-help
nodora96
Phx,AZ
My inner door latch is not working. By searching I found out that with a simple tweek to the connecting rod, connecting to the latch, it will be like new. But I think I may have tweeked it a lil too much. When I go to use the latch, it is loose and turns almost 180(degrees):emotions122:. My question's are: Is it broken?, Misaligned?, and What is the simplest way to take out the latch part? It looks riveted to the entire back-plate(thing). Thanks in advance!
99 2dr
The Real Nor Cal !
It sounds to me like your inner door handle is broken. It is fairly common. You just need to take the door panel off drill out the rivet and get a replacement handle from Napa or the dealership. The plastic body of the handle slides into place. I have had much better luck with the dealer replacement handles. I would straighten out the rod in the door as close to factory as possible too. When I put the new handle in, I use a self tapping screw instead of a rivet which makes it much easier to change it again. Out of the 5 tahoe's I have had all have needed either the left or the right replaced.
nodora96
nodora96
Phx,AZ
^^^ Thank you, that is exactly what I needed. I kept trying to trouble shoot it. Thx
xX Mavr1ck Xx
Middle Tennessee
Well I got mine in today and installed it. Pretty simple task. If you needs some help with it lemme know.
xX Mavr1ck Xx
Middle Tennessee
^^^ How is the product itself?
Well this one has a different texture to it, and isnt the exact same color. its more gray than black. But its made out of metal it feels like, unlike the plastic stock one. I took out the old one and it went into 2 pieces lol. It feels like it was made very well.
Also: Keep the weather plastic from your old one and put it one the new one.
Da90
Tulsa, OK
I bought Escalade/Denali chrome door handles off ebay. They have lasted over 2 years. I bought a set of 2 for like $60.
briannorris
