i need help asap
edd112
can someone please help me out?? ive been having a problem with my 2004 tahoe 5.3 flex fuel. first it started to rough idle and stall. now it doesnt even turn on. ive changed crank sensor, fuel pump and fuel filter and o2 sensor. its been through 3 mechanics and none were able to find the problem. the truck is all stock only upgrade was a bullet exhaust and led tail lights. its not fuel pump relay, ive tried a new one and still no start. the starter does work, the engine just wont start, it has proper fuel pressure and had spark plugs and wires changed. what could be wrong???????
edd112
edd112
Yep, please list any codes. Just shooting from the hip, it might be knock sensors. Could also be your intake gasket.
Have no access to a scanner . Bad knock sensors can cause no-start?
An OBDII scanner can be had for less than $100 at your local auto parts store. It's a necessary tool for troubleshooting and will pay for itself very quickly.
Well it won't start so that might be a problem even if he does have one since they require the vehicle! Unless towing is an option.
cmc76
where are you from? there may be a local member who can help you out in the short term. otherwise, i think i got my scanner at harbor freight for like $75 on sale.
afpj
Is there actually a spark at the plug? Also check ground cables, especially one from engine block to firewall.
k09viper
