I just ordered some Ford torsion keys
axekick
Austin, TX
I won them for $26 + $10 shipping on ebay. Hopefully I get them soon. I want to put them on this weekend. Now I just need to find a deal on some meats.
axekick
axekick
Austin, TX
I was just going to turn it up in the front enough to level it with the rear. Can I get enough out of the keys to allow me to put spacers on the rear and still get it level? That would be a pretty sweet poor mans lift.
AquinoSteven
Key and Spacer Guru
Clinton, NJ
I would go with 33s to be safe. I have a 8.5" rim and i regret not gettin 10". If you wanna go for the wide stance
axekick
axekick
Austin, TX
I like body lifts but not for the Tahoe. I'd like to get some 32" or 33" tires under it. It will look good. I'll definitely check into the coil spacers.
odie301
Kasson, MN
i did the ford keys and i can clear a 33..the ones i tried were a bit wide and hit the plastic piece below the bumper when turning...
BUT i think my driver side torsion bar is funny, as it is fully cranked w/ the f150 key..and my passenger side is only maybe 1" in and its level all the way around. I think maybe the torsion bar got turned a slot one way or another from its stock location on the a arm. So if the driver side was like the passenger i know i could go a couple inches higher and then would need rear coil spacers.
axekick
axekick
Austin, TX
Okay, I got my ford keys. Where can I find a 1" spacer? I think ebay only has 2" or more spacer right now and I don't want to lift the rear that much. I'll put the Fords on this weekend and start trying to find some rear spacers. I won't be getting it aligned until after I get the rear set and the front level with the rear. I really need to find a good deal on some tires.
ZaZaZazzels
