humming noise driver side front wheel while turing left
maverick
I could use some help diagnosing what's wrong with my 2000 Yukon, 4wd, SLT. I just changed out my front left wheel bearing hub that took care of a bad grinding noise. Now I have a humming noise coming from the same wheel only when I turn left. There is no clicking noise coming from the CV joint and the humming noise show up at speeds of 25+. It sounds exactly like snow tires humming on the highway, but only when I turn left and it wasn't there prior to changing the wheel bearing.
swtz71
Mass
Right side hub... when you turn left you are putting pressure on the right side.
Gordy
Right side hub
+2 It probably was not audible while the left one was grinding.
albac
