How Much Can I tow
177mph
Jersey
There are web sites where you can find this info. Ones dedicated to trailers should have a guide. Depends on your year as well. Be careful with the factory hitch if you tow heavy. Many have failed and caused accidents. I upgraded mine right away.
DallasD
I know it says that the 5.3 can tow like 8000lbs
DenaliAK
Colder than you
Alaska
The new 4.8's towing capacity is 4500lbs. I'm thinking yours is probably right around there somewhere.
Max
Mile High
Denver
I wouldn't try more than 5000lbs and you may want to invest in some inner spring helper bags if you plan on towing quite a bit.
05Yukon
Houston
Are you sure you have a 4.8? I thought you could only get the 4.8 in 2wd. Maybe that was just the later years.
Durobans
