How big can I go with coil spacers??
01yukon
Lynchburg, Va
First, I was wondering if I can up spacers in the front, if so, how big before I run into problems. Second, how much can I put in the back?? I have keys up front and .750 spacer in the back. Thanks!!
MOBmentality
Has a $25,000 Punch
If you have torsion bars... then you dont have coils.. a torsion bar IS a spring..
---------- Post added at 07:36 PM ---------- Previous post was at 07:33 PM ----------
you CAN do a 3 inch spacer in the rear and turn the keys up to 3 inches up front.. but the rides not gonna be amazing
road1will
pretty pretty good
Johns Creek, Georgia
As Mob said, no you can't put a spacer up front, you have torsion bars.
I've never felt comfortable with more than a 2" Spacer, some people say you can do more, but I wouldn't run anything past 2".
MOBmentality
Has a $25,000 Punch
They make this sick billet 3in for them.. that looks pretty safe.... but i would NEVER go more than 3.. not even on bolt ins
Max
Mile High
Denver
Anything over 1.5" is sketchy unless you flex it out and get the perfect shocks spec'd out. I'm trying to find a set of h2 coils to try on another member's truck in hopes that it will sit about 1" higher than his sagged stock coil + 1.5" spacers.
Narco
Atlanta
stock coil spacers? do they all have them? i dont remember pulling one out on mine when doing the drop
TheFuzz
Idiot Police
Spurbury, VT
The spacers aren't stock, just the coils are, and they are pretty worn out. I might end up getting some fresh torsion bars too just for the hell of it, I'm sure they are sagging a bit even with the keys cranked up quite a ways.
