Homemade Windshield Washer Fluid
Jason in DLH
Cheeseburger and Fries
MN
Here’s a recipe for washer fluid that you can make yourself that will save you a bit of money and will apparently help the environment a tad...
-8 ounces 99% Isopropyl Alcohol (double this in freezing temps)
-1 ounce liquid Castile soap
-4 drops Blue food coloring (optional)
-1 Gallon water
Pour IPA into empty jug first. Then fill with water. Slowly add soap and colorant. Cap the jug and turn upside down slowly a few times to mix. Done.
Here’s the original recipe (scroll down and see how the lady broke down the cost of DIY vs store bought)...
https://www.diynatural.com/homemade-windshield-washer-fluid/
Bill 1960
Testing the Limits
If not in freezing weather, I have gotten by a few times just using water and a few ounces of vinegar. The vinegar is to acidify the water a bit and reduce any tendency for water spots if it’s hard water.
Jason in DLH
Jason in DLH
MN
Even better yet!
St. Louis
I just buy the $2 gallon jugs at Walmart...lol
The - 20 below washer fluid usually has about 30-35% methanol to keep it from freezing.
I also use it in my supercharged mustang that has a meth injection system, but I'll add a bottle or two of the yellow HEET, which is mostly methanol, to bring the percentage up to about 50%
exp500
And some soaps change the freezing properties. Dawn is great for bug scraping with water, but when freezing with -20 blue will freeze soon as it hits glass and smears. Takes a few flushes to clear out the soap.
Dh1280
