hole for 0 gauge cable in yukon 06 firewall ?
johnnyq8
here is my build
http://www.amazon.com/Kenwood-KAC-2404S-500-Watts-Bridgeable-Amplifier/dp/B004NTTCDA/ref=pd_sim_e_30
this is going to be for the speakers
http://www.amazon.com/Kenwood-Kac-8105D-1000-Watt-Class-Amplifier/dp/B0038FHHHS/ref=pd_sim_e_22
this going to be for the sub
2 pair for this
http://www.amazon.com/Kenwood-Kfc-P...mance-Component/dp/B0037PH2CY/ref=pd_sim_e_11
this is the sub system
http://www.amazon.com/Polk-Audio-DB...ie=UTF8&qid=1358581659&sr=1-3&keywords=1212db
+ 2 pair of scosche 6.5 spacers .
+ pair of the install bay 6.5 speakers baffles for the front ones .
+ pair of XTC 6.5 speakers baffles for the rear ones .
+ RockFord 0 Gauge dual amplifier wiring kit .
http://www.amazon.com/Rockford-Fosg...842&sr=1-4&keywords=rockford+amplifier+wiring
i already have all this stuff but im upgrading my cheap wiring after it shorted my Subwoofer amp thank god it was covered by the warranty , im little concerned where to find an existing hole to run a 0 gauge cable with about 3 mm more bigger because im going to cover the power cable with cable hosing , do i need to drill ? + the true wattage of my system ohm's is going to be about 750-800 watts max do i need to do big 3 upgrade or add cap or im going to be fine , im replacing my stock head unit with Kenwood DNX6190 , BTW how is my build ? thanks in advance
JKmotorsports
Austin, TX
Most of time I will drill a new hole in the firewall and use a rubber grommet, especially for 4ga and larger.
When adding any decently powered amp, you should always at minimal upgrade the ground cable from the battery.
anthonyz71
Black Death Bubonic
rockaway , nj 07866
i will be running my 4 runs of 4/0 awg graden hose in my frame . then 10 runs from battery plant to my amps :) if u need to ask Y 30,000watts
MrBalll
West Texas
How does that help him?
As far as the Big 3, why not. It can't hurt anything. Like JK said, just find somewhere and drill a new hole and plug it properly.
magicbus
Wichita Falls, TX
There is a little piece of plastic on the inside, next to the brake pedal, where the clutch pedal gets installed for manual trans vehicles. It is pre-cut and has a tab you can grab to remove it. It's where I always drill for new power cable
Chevy1234
