Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
it will not be anywhere near that price if you go on SteveMeadeDesigns.com/board
find Rob in his section and message him.. tell him that I referred you to get an alternator and he will lower the price
that alternator does well over 200 amps at idle and 270 amps at 2k RPM
all great company's but I have personally dealt with Rob so I know his customer service.. he actually threw in an overdrive pulley for free with my alt so I could get close to 230+ amps at idle and still well over 270 amps at 2k rpm
he can custom make you a larger alternator if you would like but typically the way they are designed the at idle performance suffers which is why when most people run up to 4 alternators they have a master alternator that is around 220 amps peak so they can still have a good at idle voltage
thanks for the info.........will check out the prices from these guys.....btw how many of you guys replaced ur factory alt........or just added another to ur factory........
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
