HID Install Help
RCE1313
Louisiana
I ordered the DDM HID Kit (H11 & H16). For some reason the stock bulb when I pulled it out has a lot larger plastic housing that the bulb is attached to. The H11 plastic housing is a lot smaller and doesn't just slide in the hole of the headlight and twist to lock in place. Is this right? Not feeling too confident about how things are going. HELP me please!!! Did they send the wrong bulbs?
Modded
That Guy
I assume you have an 07-Up Yukon by your default pic?
If so, Yukons are supposed to have a H13 bi-xenon bulb, so if you ordered an H11 bulb kit (which is meant for the 07-Up Tahoe) you ordered the wrong thing.
RCE1313
RCE1313
Louisiana
That really sucks!! Do you know if the fogs are the same? Well I hope I'll be able to return the bulbs to get the correct ones. Thanks for the help!
---------- Post added at 05:23 PM ---------- Previous post was at 05:11 PM ----------
Do you know if the H13 Hi/Lo are the correct bulbs to get? I see on the ddm website they have H13 listed twice. H13 and H13 Hi/Lo. I'm assuming I need the Hi/Lo.
Modded
That Guy
You're welcome. Yeah the fogs are the same, they are 5202 bulbs, some call them H16 bulbs also.
And yes you need the H13 Hi/Lo (bi-xenon) because your high beams use the same bulb the low beam does, it just gets brighter.
Conedaddy
