HID bulbs. 25-100watt
ezdaar
Chat Troll
Redneck central, Aka Houston
Ok, so I am upgrading my HID's to higher wattage.
So far the only difference between 35-55 watt setups that I have seen is the ballast.
My question is there a diff between a 25,35,55watt and 100watt hid bulb?
My 35 and 55 watt bulbs are identical.
Reason I ask, is HIDGeeks sells 100watt kits but only with 5k and higher kelvin. So I was thinkin order a set of 4500's from DDM and plugem into the 100watt ballasts.. While giving the bulbs from HIGgeeks to a friend for 12.50 which will cover my cost from DDM.
Yess I know 5k at 55watt and higher will wash out to pure white, but I can still see a hint of blue and I dont want that. He likes blue.
I am replacing my 55's to 100's in my fogs and movin the 55's to my lows to replace the 35's and ballasts alrdy there.
I have lost 2 bulbs in a month on my passenger side, think my ballast is going bad. I dont feel like waiting for 3 months for DDM to check and send replacements, for 30$ ill order new set and have them in 4 days.
So, what you guys thik about the bulb question.
DenaliAK
Colder than you
Alaska
I don't know if this is a universal answer, but I do know that there are specifically designed bulbs for the higher wattages. You can tell almost 100% if they have a ceramic base, rather than metal. That also might give you a good idea on how hot they can get....lol.
I wouldn't run a standard HID bulb in a 70w or more system. It'll probably work, but could also blow up. :D
Here's a comparison shot, with standard on the left and 70w on right:
Oklahoma
You might watch out for your fog lights as well. You dont want to melt your fog light housings with those hott ass 100 watts.
Physh1
With a ceramic base those things are gonna get way hot. Probably close to what a HQI style metal halide gets.
I just gotta ask...what's the general need for anything over 55w? 55w HID's are crazy bright...I gotta imagine any brighter & you'll just get pulled over because...lol...
Cameron
DenaliAK
Colder than you
Alaska
Yeah, if anyone's fogs can take the heat, it's his. My OEM plastic lenses are crisping in the middle with 55w HID's, and I don't even run them very often. Eventually I'll be following his lead and getting the metal/glass retrofit.
ezdaar
ezdaar
Chat Troll
Ok guys I have a delima.
The HID kit that I want from HIGgeeks only comes in a few Kelvin selctions and as you guys know I am a huge fan of 4500k.
The kit I want is 100watts, But I cannot find it in 4500k.
So my question to you guys is, Do you guys think the 6k bulb at 100watts will wash out enough to be a VERY close match to a 55watt 4500k kit?
Or do any of you know where to get a 100watt 4500k kit?
whitehoe01
probably look like ddm's 5000k overall..
ive debating on 75w 6000k's from them but ive been hearing bad stories about hidgeeks sending things doa, wrong item 3-4 weeks for returns...just bad customer service in general.
ezdaar
ezdaar
Chat Troll
Gah! thats no good. But I have read numerous posts about DDM being the same way.
I been google searching for almost a hour now, trying to find the bulbs I want, Seems to be like finding a needle in a haystack.
Good dependable 100watt ballasts, 4500k ceramic base bulbs.
Wow, what a pain in muh butt! LOL
Andylbc
