Hesitant
jossix
I just received CCM leveling kit for my 09 Yukon but am now hesitant to install it. I do not know how the Yukon would look lifted
with the stock 17 inch wheels.Does any one have a similar setup? would wheel gap be too big? Perhaps I should wait until I get bigger wheels. I would appreciate your opinions.
Hurlz07Tahoe
Charleston, SC
It wouldn't look too bad with stock 17s and stock rubber. I had my leveling kit in with stock 20s and stock rubber for a day or two before getting my new tires mounted. I'm not a fan a big rims so I would say just keep your 17s and get some monster tires!
If youre curious just go out and jack up the front two and a half inches under the front cross-member. There should be enough suspension play that your tires will stay on the ground (or close to it). You could unbolt the sway bar end links if you need a little more travel so you can see how it might look...
fco_gonzo
Tahoe BS Detector
Arizona
it sounds like you dont want it anymore. I would return it and get a refund. If you are sweating the small stuff, wheel/tire gap, then its not for you. later down the road you;ll find some other reason to "hate" your leveling kit. either way good luck
RSymons
Texas
I like trucks to have a little rake but thats just me.
J
jossix
A little more rake? I don't know what that means.
I plan on installing the kit right after I return from vacation at the end of July
RSymons
Texas
Leaning slightly to the front! Not leaning slightly to the rear.
dizhai
