2006 Yukon Denali, bouncy ride with Vigor suspension
duggg
Las Vegas, NV
Hello all,
I know that in general the Vigor suspension has been discussed before (and in many cases warned against) and while past me now wishes I'd avoided it, I put the full Vigor treatment on my 2006 Yukon Denali several months ago. Their support, as many know, is completely nonexistent, so I come to ask the fellow owners about a possible path forward.
My issue is the bouncy ride when the Yukon is mostly unloaded, which would suggest to me either the springs are worn out, the right height sensors need adjusting (though i've tried that) or the parts I put on are just flat out junk (which is my leading theory). When there is some weight in the back (300+ lbs) it smooths out and is what I would consider borderline acceptable. But unloaded a reasonably sized bump is just about enough to make a person seasick.
My question is: has anyone had the experience of going from Vigor back to the OEM setup? Was it a notable enough difference to justify the cost? My Yukon came with a worn out set of Arnotts and given the lack of a reasonable warranty at this point, I am hesitant to go back to them. Is there another solution I'm not thinking of?
The only other idea I've considered is rolling back to 17" wheels from the OEM 20" wheels to try to gain back some cushion in the ride. I really appreciate any thoughts or experiences any of you have had.
Edit: I just now realize I've posted this in the wrong forum, I'm really sorry! Will see about moving it.
Marky Dissod
If you really prefer the GM OE comfy suspension, Bilstein 4600 shock dampers.
If you'd prefer less bouncy-ness, Bilstein 5100 shock dampers.
Despite wearing 18" wheels, very seriously reconsidering 265/70R17 tires just 'cause that size has the largest tire selection BY FAR of tires at better prices.
This may very well be your opportunity to re-select the springs you want to customize your ride quality & height ...
You can convert back to OEM, if you want to. I've had both passive and active shocks on my 2007 Yukon XL Denali, and I much prefer the OEM active suspension.
But, in all fairness, many folks like aftermarket suspension systems, as well.
petethepug
Michael
SoCal
The only real way out is a credit card dispute that goes off the grounds you were sold something not as advertised and/or defective.
The credit card Co will simply need the dates , times and email copies that went unresolved, if answered at all. When you get your dough back do OEM that have a lifetime warranty.
It’s like a bandage pull. Just do it once, knowing it’ll hurt a little, but go away forever.
jkhuntzinger
