seven9st surfer
I got a new backup camera, but need help with the installation on my 03 Yukon because the instructions are in Engrish. I've got a Sony XNV-660BT headunit. I attached some pics of the connections I'm dealing with. I know that the black connector in the first pic connects to the camera itself, the red wire taps into power for the reverse lights (I'm pretty sure, so that it turns on only when put into reverse, right?), and the black wire is a ground. Now in the second pic, the RCA plug goes into the appropriate plug on the back of the head unit. But what about the red wire? Obviously its for power, but what power should I tap for it? Constant 12v? Accessory? Any help would be much appreciated. Thanks.
