Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Yep. You'll need a line out converter or an amp that has high level inputs built-in. These will take the higher voltage ac audio signal from your stock deck/amp and convert it to a lower voltage pre-amp level signal that will work with aftermarket amps.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
