Help... truck won't start
my09denali
Installed HID lows today and now and can't get the truck to start.
I had originally put negative from HID to battery. But now I can't seem to get the negative battery cable to make a connection to the battery post. I tried connecting and reconnecting a million times. Rarely does it even make a spark when the cable touches the post.
When my interior and other lights work but the battery gauge doesn't show any power. When I try and start it I get 1 click and then nothing.
I'm pretty sure my negative connection is my problem. The truck is new nothing is corroded. I took a brush and brushed the post anyway. But that didn't work.
Any suggestions to fix this?
Thanks.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
can you get it to tighten down or is it loose? Hows the battery? Might be dead and or need a recharge.
M
my09denali
Connection seems tight. Been working on it more. At the end all my lights would just flicker. And just now the remote lock wouldn't lock the truck. So maybe I just wore down the battery. I'll see if I can find someone to jump it.
I don't think I have a good ground connection on the HID harness. The driver light would flicker before. Would having a bad ground on the HID affect anything else?
Thanks for the reply.
JeffK
