SunlitComet
OBS Jedi-Do Good
Gully the data dump is below in esxel form compatible with new and old version. I will let you look at first to figure out the raw data for fun but will explain anything you want. Not sure if the Scan XL demo version can playback log files but try it.
In short massive misfiring in cylinder 5-7 because two injector acting up a little to much at low rpm but at higher speed the injectors pick up some since being pushed harder cutting back on the misfires dramatically unfortunately while the puter thermo measured about 195 at one point the dash gauge and my IR thermo starting recording a dangerous rise in the left bank being higher in the back past 240+ so I shut it down. so that with the matching pressure reading in 5-7 leads definitely to a cylinder gasket or head crack. Plus some worn valve seals. So Now I just need to get some money together to tear them down. I could probaly do both heads with new seals and the fuel spider for about $600 which covers new fluids, cleaning, new gaskets from the heads up and an XL king arthurs supreme from round table pizza and 2-ltr mug root beer to celebrate(gone in 40 minutes tops). But not including machine shop inpection. I just need a secure place to do it once I have the dough or let some a good shop do if desparate and then get on with the rest of vehicle repairs.
http://www.sunlitcomet.com/binary/automotive/tahoe/ObdIIScan1-6-11.csv
