Help - running rough, new plugs, wires, cap and rotor
SunlitComet
OBS Jedi-Do Good
unknown at this time.
1. In that post I also said to much is never enough for me so the best solution for me with some older equipment was no solution. 18 remotes and counting with full control over every fuction on them. I do have a hp media center pc tied in not pictured with its own minidisc recorder with remotes for both. There is another older computer dedicated for storage and constant weather station data on display. Total storage =2.2 terabytes. Also 2 laptops(one old with serial and printer ports but no usb or network plug(pcmcia card for that) used mainly for rs-232 linking). Loaded business fay with neworking, storage and multiple trays. And to top it off networked HP inkjet and HP8100dnt w/2-500 sheet trays,2000-sheet feeder, envelope feeder with all trays capable of 11x17" tabloid paper, 8-bin output bin sorter and network with dedicated hard drive. Cost per page $.03 up to 150,000 pages a month.
2. 16-port switch, wi-fi router with phone ports for voip voice and fax use, 2 other wifi routers with access control options for others to go thru, 2 wi-fi access points for home theater use a few more switches and access points not pictured. Cable modem also has voip ports in use.
3. KDL46XBR9 was in production around in 08/09 but there are still new and used still around with 52 and 40 inches too.
CCFL 10-bit panel capable of full 1920*1080p/24. bravia 3 engine 240 hertzs motionflow. Four hdmis, two components(one switchable to composite), Two composite (one with s-vhs), ANalog audio in/out, Optical out for extraction from hdmis or tv digital/analog tuners, Pc input, usb connectivity, Lan port, streaming video and widgets and then some.
Dilibertly choosen over xbr10's and new 3d models. that lack video proccessing quality even while offering led light becuase they went with slower processors lower refresh rates etc. Older xbr8 had tri led but used older proccessors. New Sony XBR-60LX900 out now go back to high refresh rates better proccesors again and edge-led with 3D, wi-fi, no more s-vhs but go 60" inch big($4500). I will be getting one probably q4 2011or next q. Xbr is Sony cherry. For bedroom cant go wrong with and older xbr9 even used. Amazon dumped 30 scratch/denter for $980 in sep. where I snatched one. Save about $1200 over new.
BTW service manuals on everything.
Maybe on tha tablet but no money to even fix the truck right now.
Planned though so far is car audio with nav sytem will be kenwood excelon with rear view camera, hd and sat radio, dvd, Polk speakers Kenwood amps and enlosers for barn door subs($3600 retail). Alarm will be Clifford avantguard 5 with starter, window control, tilt, perimeter and sound sensors($700 stealth wired self install).
:Whoa:To much?
Need more info?
gulleyman
gulleyman
TX.
...2 laptops(one old with serial and printer ports but no usb or network plug(pcmcia card for that) used mainly for rs-232 linking)....
So what's that rs-232 link? They mentioned that on the carputer site when I was poking around looking for a scanner solution for my carpc...
oldsalt
My 2 cents.
Boy this is like reading my life story between Oct. '09 and Mar. '10. Spent a crap load of money throwing parts under the hood and the problem turned out to be a cracked head.
The original engine overheated years ago and I replaced it. (that stupid heater hose fitting rotted away) The block had been sitting on my shop floor so I had it re-machined and built it before pulling the car apart. Problem was that the heads had cracked in a couple of places. Instead of investing in new heads I had them pinned. Dumb decision to save a couple hundred bucks. I gambled and lost.
I had the same missing problems and replaced everything mentioned in this thread. Finally did a pressure check on each cylinder. When I heard bubbles in the coolant expansion tank I knew my problem. So I replaced the heads and problem solved. Remember this is on a new engine.
Gulley, originally your problem sounded like a bad fuel pressure regulator that was dumping fuel (#6 plug fouled first). If you replaced that along with the spider no problem. Everything you have done I also did. I was over thinking the problem and after replacing the electronic parts it turned out mechanical. Milky oil tells me you have something mechanical going on.
I guess my advice would be, at this point, if you are not able, have a mechanic pressure check each cylinder for leaks. Are your plugs fouled with water, gas or oil?
If it is a head problem, considering the mileage you have, I would replace the engine (or have it rebuilt) instead of just the heads. The time and trouble to replace just the heads will be about the same as pulling the engine and dropping in a new one. If you do replace it I would stick with a GM rebuild. I don't trust what comes from the engine companies out there. But that's me. I also, for the most part, stick with GM parts.
And stay away from that dealer. $400.00 to replace a dist. cap?! A 30 minute job tops. I did one once at a rest stop in Oklahoma.
SunlitComet
OBS Jedi-Do Good
Some of my home theatre equpment uses it for control and software updates thru rs-232 serial port.
Every thing now is usb just about.
---------- Post added at 05:29 AM ---------- Previous post was at 04:39 AM ----------
OLdsalt I hear you mine is suffering like gulley's I finally finished all the electronics fualt repair and put replaced the wrong plugs that were put in it and that alone made it worse. Iwill post pics of my plugs soon but right off my 5 7 cylinders are coated with oil so that coupled with the oil I see on the block mating surfaces between those cylinders on the outside just precluded that my left head is going to have to come off for inspection. I am already broke and this deal announced for unemployment compensation just left me hanging in the wind so now I have no way paying for parts or head work and getting it back together afterwards. Until I can get a working vehicle I can not get back on the road for work again. To top it off my registration is incomplete becuase I have no smog yet and the apartment manager is cleaning house of vehicles on the property. Vissually it better than some of the others around hear but no tag even though I can provide proof of registration and fees. So I have to find some place to store it at more cost.
Cornbreadbruce
dfw
hey folks,my 99 ex border patrol tahoe is having the same problem as gullyman's. i'm a shade tree mech. wondering what the compression should be?
SunlitComet
OBS Jedi-Do Good
The minimum compression in any one cylinder should not be less than 70 percent of the highest cylinder. No cylinder should read less than 690 kPa (100 psi). For example, if the highest pressure in any one cylinder is 1035 kPa (1150 psi), the lowest allowable pressure for any other cylinder would be 725 kPa (105 psi). (1035 x 70% = 725) (150 x 70% = 105).
1. Disconnect the positive ignition coil wire plug from ignition coil.
2. Disconnect the fuel injector electrical connector.
3. Remove all the spark plugs.
4. Block the throttle plate wide open.
5. Charge the battery if the battery is not fully charged.
6. Start with the compression gauge at zero. Then crank the engine through four compression strokes (four puffs).
7. Make the compression check the same for each cylinder. Record the reading. The minimum compression in any one cylinder should not be less than 70 percent of the highest cylinder. No cylinder should read less than 690 kPa (100 psi). For example, if the highest pressure in any one cylinder is 1035 kPa (1150 psi), the lowest allowable pressure for any other cylinder would be 725 kPa (105 psi). (1035 x 70% = 725) (150 x 70% = 105).
8. If some cylinders have low compression, inject approximately 15 ml (one tablespoon) of engine oil into the combustion chamber through the spark plug hole.
o Normal - Compression builds up quickly and evenly to the specified compression for each cylinder.
o Piston Rings Leaking - Compression is low on the first stroke. Then compression builds up with the following strokes but does not reach normal. Compression improves considerably when you add oil.
o Valves Leaking - Compression is low on the first stroke. Compression usually does not build up on the following strokes. Compression does not improve much when you add oil.
o If two adjacent cylinders have lower than normal compression, and injecting oil into the cylinders does not increase the compression, the cause may be a head gasket leaking between the two cylinders.
9. Install the removed parts.
10. Connect the disconnected components.
Cornbreadbruce
dfw
i've got 180psi at highest and 150psi on the lowest
---------- Post added at 10:27 PM ---------- Previous post was at 10:13 PM ----------
sooo? 126psi?
oldsalt
I should clarify my post. When I said I did a pressure check on each cylinder I did not mean a compression check. On the cylinder that gave me a misfire code I brought that to cylinder to the top firing position (both valves closed) then applied air pressure through a hose screwed into the spark plug hole.
The first cylinder I checked was bad. As stated I heard air bubbles coming through the coolant expansion tank. I replaced both heads as they were both pinned during machining. They cannot weld the stock heads as the metal is just too thin.
Now I must add that not knowing the problem, I drove this new engine with a small crack in the head from California to Georgia and back with no major issue. What made me dig into this is that I would feel a misfire at highway speed. It was so instant that sometimes it just felt like a rut in the road. However, if the engine was hot and I would pull in to get gas upon starting the car after filling up it would studder and shake until I revved it up a few times and blew out the water that had pissed into the cylinder while filling up. Mind you it wasn't much.
Only once did I get a Check Engine light. That was one morning starting the car.
The fact that the car ran and a scanner on the car while it ran showed a slight misfire on #4 cylinder is what made me start replacing electronic components (plugs, wires, caps, rotors, coil, etc).
gulleyman
gulleyman
TX.
Good info :D may need this myself VERY SOOON :Frustrated:
Here's the pics of my plugs. The ones at the top are the original plugs before I did the tune up. In the first picture the plug on the top was reused once because I was short a plug when I got home from the parts store after returning the first set of defective plug wires. The ones at the bottom are the 2nd set that I just replaced with ACDelco Iridium plugs as per the dealers $80 diagnosis. You can click on them for a larger pic:
gulleyman
gulleyman
TX.
My 2 cents.
Boy this is like reading my life story between Oct. '09 and Mar. '10. Spent a crap load of money throwing parts under the hood and the problem turned out to be a cracked head.....Gulley, originally your problem sounded like a bad fuel pressure regulator that was dumping fuel (#6 plug fouled first). If you replaced that along with the spider no problem. Everything you have done I also did. I was over thinking the problem and after replacing the electronic parts it turned out mechanical. Milky oil tells me you have something mechanical going on.
Check out the pics I posted today, I'm pretty new at this but it looks like oil to me, they reek of gasoline too.
I was thinking the same thing, even found a couple 383's and 454's on Craigslist I thought about swapping in but I have to make sure the problem won't still be there even if I drop a fresh motor in it:emotions122:
Roger that, LOL, don't think I'll be darkening their doorstep again anytime soon!
With the help of the folks on this forum and a couple others, I am in the process of building an on-board PC with OBD2 diagnostics built in. I already have the PC so I just have to buy the OBD2 peripherals and software. If it works out we'll be able to dig deeper into the issue without me personally paying the dealers rent in diagnostic fees and idiotic recommendations.
I'm also going to take it to another mechanic that's been honest with some friends of mine, he used to be a mechanic for the dealer but he left and is doing it on his own now. Hopefully he can wave his magic wrench and all this will go away for a nominal fee :Violin:
---------- Post added at 11:49 AM ---------- Previous post was at 11:37 AM ----------
OLdsalt I hear you mine is suffering like gulley's I finally finished all the electronics fault repair and replaced the wrong plugs that were put in it and that alone made it worse....my left head is going to have to come off for inspection. I am already broke and this deal announced for unemployment compensation just left me hanging in the wind...Until I can get a working vehicle I can not get back on the road for work again. To top it off my registration is incomplete because I have no smog yet and the apartment manager is cleaning house of vehicles on the property. ...So I have to find some place to store it at more cost.
:wtf2: Dude, that blows, sorry to hear 'bout all that. Hopefully we'll all be back on the road again sooner than later :(
SunlitComet
OBS Jedi-Do Good
Found storage for a few weeks to delay loosing it. Just a brief look at those fuzzy pictures of new plugss is the black coating dry fluffy powdery sorta kinda or is that wetty oily looking? May be a fork in the road kind of thing. Will be back later tonight.
gulleyman
gulleyman
TX.
I think it's "wetty oily looking" even after being out of the truck for at least a week so it' not gas...
Nikolai553
Hutchinson, KS
I've been reading this thread and links for the past hour now :Boo: ( very good info though ) and to me it sounds like you have spent a small fortune on just trying to find the problem. I believe it may just be time to pay the $1000 or so and replace the whole engine with another engine. Because it seems like you have a long way to go towards spending more money on this same issue.
Oh and I like the idea of having a portable laptop that has diagnostic capabilities. That is definitely on my list of "to haves".
well thats my opinion at least
gulleyman
gulleyman
TX.
...sounds like you have spent a small fortune on just trying to find the problem. I believe it may just be time to pay the $1000 or so and replace the whole engine with another engine. Because it seems like you have a long way to go towards spending more money on this same issue.
Welcome to the forum :waytogo: I'm actually only into it for about $400 at this point, looks like the OBD2 peripherals and software may only be about $200 :D plus gotta make sure I don't drop a grand on a fresh engine only to find out it still has the same misfire :doh2:
Check out my other thread if you want to "geek-out" on the carpc, go'on you know you wanna...
http://www.tahoeyukonforum.com/forum/showthread.php?t=20898
Nikolai553
Hutchinson, KS
thank you and wow! :jawdrop: only $400? after page 8 it seemed you were spending alot more then that.
I did read that thread actually, but believeeee me when I say I will geekafie my interior ;D
SunlitComet
OBS Jedi-Do Good
Gully will not get my pics up tonight maybe tomorrow but I have included plug chart but no pictures(look in the back of any haynes manual. Wet oily heads towards bad rings or valving trouble. Compression say your rings are fine so i would like to question valving. Was this on all the plugs? Can you tinker manual camera settings to improve photos maybe with a white sheet background?
gulleyman
gulleyman
TX.
Thanks sunlitcomet, those were the best I could do with my phone. I have a really nice Nikon but I don't know if the pictures will be small enough to post here. I'll try to figure something out tomorrow.
Nikolai, be sure to post up when you do :D
Joe M
I attempted to read all the posts, but was wondering if you have ever cleaned your mass air flow sensor. The reason I ask is because you mention the engine improved with a reduction in spark plug gap. So, there is definitely enough spark, and the fuel is not the issue or is the oil into the cylinder. So that only leaves the oxygen into the cylinder. If the MAS is dirty it could be sending incorrect information to the ECM, causing the computer to over compensate for the incorrect info.
My first thought was cap and rotor or coil, but once the fowling-out moved from one cylinder to another that seems like the ECM. But the ECM is either bad or is receiving a bad/incorrect reading for a sensor.
I only mention cleaning the MAS because it costs practically nothing to do and should be maintained with an aftermarket intake assembly.
Good luck.
Buford bubba
