help on big 3
rcracerlol
Where do u run your neg Batt ground too chassis and engine? like what location if someone can take a few close ups pictures so i have an idea thx.
drowndindreams
Unknown
i doubled up on my existing wiring. the battery is grounded to the firewall right next to it.
DJTricky
Banned
Robbinsdale MN
i have 2 engine grounds. 1 from the back of my alternator and one off the driver side head.
then i have 2 negative runs, one from the battery to the frame. and one from the body to the frame. all using 0/1 gauge wire.
for the positives i have 1 run of 0/1 from my alternator to the battery, then i have one run of 0/1 to my distro block in the back to the other 4 battery's. there all grounded to the frame. same with each amp. the ground is through the floor to the frame.
coming off the 4 batterys in the back its fairly simple. there is a battery for each amp. there are 4 amps (3 for the subs and 1 for the doors.)
all power wire is 0/1. hope this helps kind of. if you have any questions just PM me.
R
rcracerlol
Cool i will PM u soon once i get 10 post up haha newbie here..
i just order knukonceptz kolosus 1/0 gauge on ebay
R
rcracerlol
Still need to find a good place to run ground wire thinking of just replacing the stocks out with 1/0 gauge. this is how far i got with it
if u guys have pictures of where and how u did your grounds plz post them
the truck is a 2000 escalade but its the same as a 1999 tahoe
briannorris
