HELP: how do i remove dome light covers?
TheBigler
Mobile, Alabama
i cant figure out how to take off the dome light covers every time i try to remove it with a screwdriver i hear the plastic cracking and i don't want to continue if I'm doing this the wrong way. I am trying to install some LED bulbs i got for it so any answer's would be appreciated.
picture.php
ALSO: if you know how to change the rectangle shaped map light covers that would be help full. i just found the thread on the round ones.. http://www.tahoeyukonforum.com/forum/showthread.php?t=16107
Brandon X
Michigan
Just take something thin and wedge it in there and pop it out. It's held in by clips. It's not that hard.
the big blue bus
richmond, va
they should have a lil slot where u cn put a screw driver in. i took them all off the other day to look at the bulbs
murray
I was thinking the same thing we have a brand new hoe, I got some LEDs I don't want to break the cover off did you come up with a good tool? Thanks
twopoint
Kitsap County WA
I realise this is a couple of months old
but just in case you run into this, use a small suction cup,
like the end of a nerf dart. push up and turn lightly!
Dr. Overkill
El Cajon, CA
I just got on to the forum to ask how to get to the dome light bulbs... What I don't know is if you have to remove the entire domelight assembly from the headliner, or if you just remove the offwhite cover from the center section.
TigerEyz3
Slow and Steady
TN
As sunlitcomet said... remove just the cover to access the bulbs.
glazar
