Hello from way NorCal
jeremiahm
jeremiahm
Way North CA
Here is what I have done in the 10 months I have owned her.
- Shocks, struts, 1.5" front lift, 1" rear lift, new air ride compressor
- Big roof rack, has travelled between my last 5 SUV's
- Mounted Viar compressor in second battery tray (will post pics)
- Cam sensor, Crank Sensor, Front main, PCV, Oil pressure sensor
- Big 3-ish wire upgrade
- Plugs, Wires, exhaust gaskets
- Radiator, thermostat, trans cooler lines
- 2 door handles
- LED interior lights
- 18" Weld EVO Forged wheels with KO2's (in garage)
- Oil pump, pickup tube o-ring, rear main seal, oil pan gasket, low oil sensor, water pump
- Complete Spohn rear end, rear sway bar bushings
- UCA's and TRE's
To do:
- Steering rack
- Front Sway bar bushings and links (in garage)
- Front wheel bearings (in garage)
jeremiahm
jeremiahm
Way North CA
Yes, 6 years, first two are school. When he re-ups, they count the two school years toward that, so he is on for 2 more.
Multnomah Falls
My claustrophobia would never let me be under water in a sub. Plus, at 6'4" tall, at that time that was too tall for sub duty.
fishcop076
