Heater hose Tee connections
How common do the heater hose connectors at the firewall fail? I have a 2010 Tahoe with 144k miles and wondering if I should proactively change them? Anything else need proactive replacement? Thanks
my experience has been they can fail anytime after 10 years the plastic gets brittle from being subjected to hot/cold over and over. if yours are the original 13 year old one's I would replace them. I now replace mine at 5 years just for good measure, because when those blow out (at any time) you generally do not know it has happened unless you are stopped and see steam. moving they just blow all the coolant out and you overheat and if you are not paying attention you do not even know until it either looses power or you get reduced engine warning and by then you have already overheated and you don't get too many chances when overheating a engine once or twice and you most likely fine but more than that and you are risking serious engine damage.
and if they do not flat out break off then they will just slowly leak coolant out until you end up in the same position as above unless you are studious about checking under the hood or notice a puddle in the garage or driveway.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
I had a very slow leak from them on my 2005. I did them about 1 year ago. Do them now if you have never replaced before. They will "give up the ghost" but never in your driveway. Although, I must say, I found mine leaking in my driveway.
I agree with the comments above. At your mileage, you should replace the Tees and ALL cooling hoses in the engine well. You can see the manufacture date stamped on the hoses, and I'll bet that yours are the original hoses. For Tees, use only OEM plastic Tees (no Dorman Tees), or use metal Tees made by Gruven.
I can tell you from personal experience that losing a Tee or the heater hose that connected to the Tee will empty your motor of coolant within 60 seconds.
Last, when you replace the Tee, use gloves, as the insulation on the fire wall is quite aggressive, or your hands will be itching for a few days.
Plimbob
Des Moines Iowa
My 07 went at about 195,000, in eastern MT pulling a boat to Fort Peck. It was a real PIA situation. Luckily, I carry a tool box on trips like that and had some radiator clamps and water. Gerry rigged it, to get to the next town. No parts available so had to improve on the gerry rigging and fill with coolant. Drove it on to Ft Peck, fished a week and drove it back home about 1,200 miles in total to and fro on the patch work. Watched it like a hawk as you can imagine.
My humble suggestion, if you're past say 125k replace it.
Geotrash
Dave
Richmond, VA
Ok, I’m the original poster. Had the work done at local Chevy dealer and the tees and hoses replacement were by far most expensive part of repairs. About $750 + for that with labor being $450 of that.
Wow. What a ripoff! I've done it on 3 of these vehicles now and it never took me more than an hour - including the first time. Now it's more like 30 minutes, and that's if I change the heater hose with the wye in it all the way down to the water pump.
Foggy
KS
Holy Shit !!! $750 for tee's, coolant, even if you did all the hoses on the whole
vehicle... holy crap..
I'm in the wrong business too !!!
Sorry for your loss Rick10.. But at least you won't get stranded !!
OR VietVet
Willamette Valley
When I ran shops, if I needed to hire a tech, typically a dealership tech was my least favorite hire. I did get a few that were good techs but the majority of them were guys/girls that had been trained to do just enough to do a job and they were not concerned with comebacks. So many knew "shortcut tricks" that were not conducive to quality work. Give me a tech that had worked in a family shop atmosphere any day.
TerryKing
Vermont, USA
Hi Everyone, OK Now I understand better. Mine blew this morning on a short run. Phew.
Hose broke at firewall, looks just like the photo 3 posts up.
PLEASE point to overall How-To for replacing these hoses and the funny connectors! I'm worried I d not undersand the connectors.
Thanks!
Regards, Terry King
...In The Woods In Vermont
The one who dies with the most Parts LOSES! WHAT DO YOU NEED??
OR VietVet
Willamette Valley
Thanks!
Regards, Terry King
It would help to have vehicle info.
There are tools available to disconnect those connectors, but in my experience, none of them worked effectively for me. Folks on this Forum have recommended to first push in the connector and rotate it slightly. Then, while pushing in the connector, push in the two tabs on the connector and pull them apart, while holding the tabs pushed in.
If the above fails, then you can take a pair of pliers and break the connecting plastic piece on the connector, just below the tabs.
IMPORTANT: Wear a pair of gloves when working on the Tee connectors, as the insulation on the firewall is quite aggressive, and you will be itching for the next few days.
Also, be sure to replace ALL heating and cooling rubber hoses as part of this project, as you will probably find the original manufacture year stamped on the hoses.
Don't fret, some of our friends here have not seen how high prices are these days for labor. Just like going to a doctor or lawyer, you are paying for their expertise.
I just bought half the hoses needed to replace all, $150 for GM OE and will be ordering the other half soon. I reckon I better just go ahead and replace the radiator too, all that yanking on the old hoses is likely to split a tank from the core with my luck!
Amazes me how many people still think the dealer is a good place to get your vehicle fixed.
Most dealerships have highly trained professional mechanics that specialize or are very familiar with the vehicles you bring to them.
slowride77
Kansas City, MO
Been looking, but cant find a thread that details all the part numbers needed to complete the Tee and Hose replacement.
I found the black GM Tee: 15055342
The white GM Tee: 15055343
The heater core GM hose: 22885825 (appears to have the crimped on quick connector to attach to the 15055342 black tee)
My question is the last hose. The one with the built in Tee in it. It is a GM 18221L ?
And if so, it doesnt appear to have the connector crimped on for the heater core tee.
So, would I also need the GM 34000 for that connection? Or does it simply slide onto the 15055343 white heater core tee?
HeavyHoe03
