heater help please!
bigfeet
Barrington, RI
I have a 98 Tahoe. The heater worked on and off all winter. I replaced that $30 resistor piece that goes on top of the box and it didn't help. By the end of the winter the heater barely blew at all. It was hot but the fan was almost totally dead. As soon as the weather got warmer, now it works perfectly. Any ideas. The colder it was this winter the worse it worked! Thank you
Donnie Yukonie
Yates Caretaker
well sounds like your problem is actually in the fan itself not the heater . does the problem stay the same with the A/C
bigfeet
bigfeet
Barrington, RI
I never use A/C. Used it once last week it was fine. The crazy thing is all winter the heater was on and off, mostly not working or barely working. Then as soon as the weather turned, now it works fine. Blows hard as anything!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
either loose wiring or contacts in the fan switch or the commutator on the blower. you need a voltmeter to help narrow it down.
JeffK
